vacuum hoses??
Old May 9, 2002 | 04:02 AM
pesky32822's Avatar
pesky32822
vacuum hoses??
does anyone know where i can find a diagram to show me where to hook up the vacuum lines that are blocked on my truck?? it is a 300six and there is a lil block under the carb that has two lines coming off that are blocked and on the other side there's is i believe two line blocked that are coming off the round black thing i forgot what it is called my dad told me but i forgot anyway any help whould be greatly appreciated
Old May 9, 2002 | 04:41 AM
Thudpucker's Avatar
Thudpucker
vacuum hoses??
I have to do this myself. My 77 is going back together and I have a mystery Vacuam connection.
In the Public library, Reference Section, you'll find a rather large book on Emissions.
It'l have your Truck listed. With the Vacuam line schemetic.
My 78 300 was probably like yours. My Nieghbors 79 was a Nightmare of Hoses. Big difference.
My 78 had one large vacuam port for the Brakes. Two smaller Ports for the Vacuam Advance, and the Hot air Chimney in the Air cleaner.
Those two came out of the Carb Base.
The Manifolds crack on those 300 Sixes. Someone may have installed a manifold from a Wrecking yard, and you got some vacuam port's you dont need.
The Emissions testers are not supposed to test anything with blocked off ports. He'll send you to the Referee.
Watch out for the Emissions referee. If he sees something Blocked off, he will make you upgrade to the Emissions level of the Blocked off ports.
Old May 9, 2002 | 06:00 AM
D9351's Avatar
D9351
vacuum hoses??
