Wild Wipers
Old Oct 23, 2005 | 09:55 PM
429f-250's Avatar
429f-250
Question Wild Wipers
My newly aquired 93 and 94 f-250 plow trucks both suffer the same symptoms. My wipers run continuosly in the delay modes so I started by changing the blinker/wiper control on the column. the 93 gained blinkers without suffering the loss of fuses so it fixed one problem. The wipers however still remain uncontrollable. I also find I can not shut them off after I press the washer button. I can hear a clicking behind the glove box is there a possible wiper control module in there somewhere? any suggestions as to the cause of this dilema would be greatly appreciated. Thank you!
Old Oct 24, 2005 | 01:16 PM
quicklook2's Avatar
quicklook2
wiper control module is attached to a defroster duct by glovebox.
to access, remove glove box, manual says to disconnect battery, use flat screwdriver to remove w.c.m. from tabs on bracket.
Old Oct 24, 2005 | 08:13 PM
429f-250's Avatar
429f-250
I will give it a try and reply with results thankyou
Old Oct 25, 2005 | 01:46 AM
midlf's Avatar
midlf
I had that problem and it turned out to be a bad park switch on the wiper motor. Only cure was to replace the entire wiper motor.
Old Feb 6, 2006 | 08:16 PM
429f-250's Avatar
429f-250
I replaced the wiper motors on both trucks and the problem is cured thanks midlf for your help
