Dash Lights
Old Oct 23, 2005 | 08:24 PM
RJString's Avatar
RJString
Dash Lights
This is an odd one. When I turn the park/headlamps on in my 97 E150, the instrument cluster lights don't come on (climate control lamps work fine) and the bright headlight indicator comes on. When I turn the headlamps on bright, the indicator goes out but still no dash lights. One other thing...With the seatbelt unbuckled the buzzer makes a strange sound and when buckled the buzzer goes of but the dash indicator has faint glow. Any help would be greatly appreciated. Thanks
Old Oct 24, 2005 | 06:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 24, 2005 | 01:39 PM
Franklin2's Avatar
Franklin2
When electrical in a vehicle starts doing crazy things like that, it is usually a bad ground. I would pull the dash cluster, and check the plug and check the wires going from the plug. One of them is bolted to the sheetmetal under the dash. Sounds like the dash lights are trying to ground themselves through the seat belt circuit. That's why it is glowing dim.
