RUST EVERYWHERE
Old May 9, 2002 | 03:48 AM
pesky32822's Avatar
pesky32822
RUST EVERYWHERE
ok i am tryign to find out what a good way is to get rid of rust in my truck it has it all around the doors in the cab not in the doors but where they meet the cab this is my first truck/car i got it about a month ago it's a 75 one owner with a 300six and 3 on the tree with 90xxxx orignal miles on it anyway i just want some opions on what whould be the best way to fix the rust i don't want to drive a pile of rust around if ya know what i mean. any help whould be great
Thanks
Chris J.
Old May 9, 2002 | 11:54 AM
Fastcat's Avatar
Fastcat
RUST EVERYWHERE
The only way I know to get rid of rust is to cut it out and weld in new metal. You can slow some of the surface stuff by grinding or sanding it down to clean metal and repainting. Good luck with you new project.
Old May 9, 2002 | 12:02 PM
dfisher1's Avatar
dfisher1
RUST EVERYWHERE
Pesk,
I am a firm beliver in the sandblaster. It's the only thing that can work on the rain gutters around the doors. After you get bach to clean metal treat it with OSPHO or some metal prep that has phosphoric acid in it. If bondo is applied use duraglass. This green bondo is stronger and last longer. Always seal your bondo when not working on it. Don't drive around town with exposed bondo. It is porous and will transfer water to the metal.
KingFisher
Old May 9, 2002 | 12:51 PM
catbird7's Avatar
catbird7
RUST EVERYWHERE
