Sponsored by: Auxito
brake problem
Old Oct 23, 2005 | 06:20 PM
khomyttboy's Avatar
khomyttboy
brake problem
I replaced brake rotors and pads on my 98 f-250 LD, also a anti-lock brake sensor on the driver's side front. I was experiencing heavy "chattering" when I would brake, and my antilock brake light would come on. Unsure as to how to correctly align the brakes for the new cable, I took it to a private mechanic who wants to replace the hub bearings, based on his diagnostics, but he didn't say anything about re-aligning it. Is his approach valid, and how much should I expect this to cost?
Thanks!
Old Oct 24, 2005 | 02:30 AM
code_red's Avatar
code_red
the bearing shouldnt be much , however the labor will hit you in the pocket.
