Oilpan
Old May 5, 2002 | 09:17 AM
j_whit's Avatar
j_whit
Oilpan
I got a 400 out of a car and I started wondering if the oilpan Will fit in a Super cab truck. and I was wondering if 4x4 engine towers were different than a 4x2.
Old May 6, 2002 | 11:51 AM
j_whit's Avatar
j_whit
Oilpan
[updated:LAST EDITED ON 06-May-02 AT 12:52 PM (EST)]
Old May 6, 2002 | 12:03 PM
birdog79F150's Avatar
birdog79F150
Oilpan
Dont know if this will help or not but i put a engine out of a 84 LTD into my 79 f150 2wd and didnt have to change the oil pan and the motor mounts were the same also. Hope this helps.
Six strings and Ford trucks music to my ears.
Old May 6, 2002 | 12:05 PM
j_whit's Avatar
j_whit
Oilpan
hey birdog79f150 was the oil pan sump up infront of the engine
Old May 8, 2002 | 12:50 PM
j_whit's Avatar
j_whit
Oilpan
Old May 9, 2002 | 01:46 PM
bluechow's Avatar
bluechow
Oilpan
Old May 9, 2002 | 05:09 PM
dfisher1's Avatar
dfisher1
Oilpan
J,
Ford has a power plant division. They have traditionally only had one oil pan for one motor. Ford only had front sump for years and years, then cam the mustang with the sump hump and now they make them with rear sumps. For our Era we're safe with our front sump. As far as the perches go you need to find out which family your existing motor is from, 335, 385, FE, etc. If the family is the same your good to go.
My Way is the Highway,
KingFisher
Old May 10, 2002 | 01:07 PM
j_whit's Avatar
j_whit
Oilpan
Thanks dfisher for your help. the towers are from the same engine I just didn't know if Ford Made two different towers for 4x2 or 4x4.
Old May 10, 2002 | 02:52 PM
dfisher1's Avatar
dfisher1
Oilpan
j,
I'm sorry i didn't pickup on that detail.
I don't know.
KingFisher
Old May 10, 2002 | 04:17 PM
dzjammer's Avatar
dzjammer
Oilpan
The FE had different pans for 2wd vs. 4wd. 4x4 had a rear sump. Don't know about any other engines.
The 4x2 vs 4x4 mounts are probably different because of the crossmember. On 2wd's, the engine perches sit on the crossmember because its under the engine. On 4x4's the perches have to go all the way out to the frame siderails with no help from a crossmember.
Old May 10, 2002 | 06:11 PM
Mil1ion's Avatar
Mil1ion
Oilpan
Just take the pan to someone who welds and have them put a drain plug in the bottom of the pan nearer the back.
I can change my oil without getting right under the truck this way.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 10, 2002 | 11:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
Oilpan
My 78 F250 2WD 400 Front sump had a rear drain plug that was hell at oil change time. The oil spilled off the cross member in a sheet 12 inches wide. I had the pan off once and brazed a drain plug into a hammered out dip in the front of the pan. It is much easier to change oil now. I don't have any idea which will be better when I get that GMC front end installed.
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
over!
Old May 10, 2002 | 11:26 PM
Mil1ion's Avatar
Mil1ion
Oilpan
Sorry, I meant front>
I must have been thinking about it backwards.
[/font
[font color=red]
[/font]
