Sponsored by: Auxito
Heat problem
Old Oct 22, 2005 | 05:36 PM
markbo's Avatar
markbo
Heat problem
'97 f150 XLT, 4.6L At one time, whenever I turn the temp selector to heat, I'd always hear the sound of air venting, and the rush of coolant. Now I don't. It seems now that the ac compressor kicks in instead dumping ice cold air. Any ideas?
Old Oct 22, 2005 | 07:39 PM
HomerWinzlow's Avatar
HomerWinzlow
Is the compressor kicking in or are you just trying to say your heat is not working? AC will not work in the heat position, Only MAX AC, AC, BiLevel, and Defrost. Vent and Floor selections net only fresh air at the temperature selected. Now if your blend door actuator is inoperative or the door broken or the temp control **** is broken, you will also have temp control problems. It could also be that you are simply way low on coolant also.
Old Oct 22, 2005 | 07:58 PM
markbo's Avatar
markbo
Both are happening. The ac compressor kicks in on any heat setting in addition to not having any heat when the heat setting(s) is selected. Checked blend door and actuator; both operational. Recently had coolant flushed and refilled professionally. I also checked heater core inlet hose and found it to be full of coolant.
Old Oct 22, 2005 | 08:02 PM
HomerWinzlow
Sounds like the mode selector switch is bad then. It's turning on the AC when it shouldnt and may have a vacuum leak as well internally in the switch.
Old Oct 22, 2005 | 08:15 PM
markbo's Avatar
markbo
Thanks for the input, I'll try replacing the switch.
