94 ranger 5 spd speed sensor
Old Oct 22, 2005 | 03:22 PM
94Rangerbeater's Avatar
94Rangerbeater
Ok my speedometer jumps around like crazy when it gets over 55 Mph, under that speed it just kind of bobbles around. I'm thinking its my speed sensor. If it is how easy is it to fix and how expensive. Also my ABS light will come on when i have a hard brake and sometimes my parking brake light will come on as well. The abs light will stay on until the truck is off. I read through the ABS forum but didn't get a real good answer. Also where can i get some easy performance mods for this truck. 2.3L 5spd short bed regular cab black.
Mike
Old Oct 22, 2005 | 03:34 PM
RangerPilot's Avatar
RangerPilot
I have a 94 4.0L 5 speed and wobbles quite a bit under 25 MPH, I figure it's just normal, I mean it's not brand new, but just outta curiosity will tag this along with your question.
Old Oct 22, 2005 | 06:11 PM
Hank85713's Avatar
Hank85713
94s still used a cable, there is a sensor in the tailpiece but that is not for the speedo. sounds as if you either have a cable going bad or the speedo itself.
Old Oct 22, 2005 | 07:41 PM
Ken00's Avatar
Ken00
The other users have the speedo problem covered...
For the ABS light, do you have rear ABS or 4 wheel ABS. If you have rear ABS check out the link in the tech info thread at the top of this for on pulling the code. Post the results.
Old Oct 22, 2005 | 11:07 PM
94Rangerbeater
well i don't know what i have. This truck didn't come with a manual or anything. I bought it for 500 bucks and it runs great. When the speedo bounces around i can hear like a buzzing noise coming from behind the guages and inside the dash. How do i find out if the truck is all wheel ABS or just rear wheel?
Old Oct 23, 2005 | 10:39 AM
Hank85713's Avatar
Hank85713
more than likely its rearwheel abs, I think if you read the VIN someone can tell ya. as to the buzzing it sounds like the cable needs to be lubed, but I would guess that you will need to R&R the cable pretty soon. If nothing else lube it, as I recall you can pull it from the transmission side. Either graphit lube or some spray white lithium grease up the cable, spray, reinsert the cable remove, spray reinsert the cable should do it. dont need to spray but for a couple of seconds.
Old Oct 23, 2005 | 02:54 PM
seadoo's Avatar
seadoo
The speedo is doing what my 94 did, I lubed the cable didn't help, then replaced the cable still didn't help. Fianlly ended up replacing the speedo gauge itself with a rebuilt one, that finally fixed the problem. From what I was told by the place I got the rebuilt one from it was fairly common for the speedos to go out on certain year Rangers
Old Oct 24, 2005 | 07:53 PM
Ken00's Avatar
Ken00
See if you can locate the connector for testing the RABS system.
Can someone comment on the location on a 1994???
Old Oct 24, 2005 | 08:49 PM
Hank85713's Avatar
Hank85713
it hangs down by the emerg brake lever as I recall
Old Nov 28, 2005 | 12:45 PM
94Rangerbeater
If i just wanted to replace the speed sensor anyway, where would it be located at? Also do i really need a tensioner tool to get it loose or can i just use a socket wrench to replace the belt?
Old Nov 28, 2005 | 07:19 PM
RangerPilot
The VSS should be on the rear diff, that's where my '94's is. A 5/16" socket holds it in place I believe.
Old Nov 28, 2005 | 10:30 PM
94Rangerbeater
Is the differential the center round part on the rear wheel shaft....Sorry not used to rear wheel drive vehicles yet. I order the Ford repair manual on Cd, so i guess i can wait until that comes in.
Old Nov 29, 2005 | 08:44 PM
Ken00's Avatar
Ken00
Yep, and the drive shaft from the tranny connects to the front of the round thing.
Old Nov 29, 2005 | 09:05 PM
RangerPilot
Yes. That is the rear differential. It turns the power from the tranny into both wheels.
To get to the VSS, climb under the truck, preferebly from the passenger side, WHEN IT'S COOL!!! You're going to go straight under the muffler and keep sliding over til you get under the driveshaft. Looking down you should be looking right at the front of the rear diff. On top, there will be a plug coming out. You can try and get your head up to see it, but good luck with that. Use a I think 5/16" or 3/8" socket to remove the retaining bolt, then just pop it out. After you replace it, put a little gear oil or tranny fluid on the seal around it and pop it back in, then put the retaining bolt back on, tighten it down, and check it out.
Old Nov 29, 2005 | 10:09 PM
94Rangerbeater
cool, thanks a lot.
