wheel bearing cups
Old Oct 22, 2005 | 02:20 PM
JMR's Avatar
JMR
wheel bearing cups
I just put my 72 swb onto a 78 f150 4x4 frame. Now I'm going over the drivetrain to get ready to test drive.
I removed the wheel bearings and hub assembly and the cups or races seem to be sloppy. I can insert my finger and spin the cup freely inside the hub. I never had a 73-79 truck, but many 67-72.
Are the cups supposed to be this sloppy or did they wear down, or did somebody install the wrong ones?
I'm ready to drive this beast! Any help is much appreciated! john
Old Oct 22, 2005 | 03:27 PM
ranger429's Avatar
ranger429
No the races should not be that sloppy inside the hub. As loose as you are describing it makes it sound like you need a new hub.
Old Oct 22, 2005 | 03:32 PM
User 71024's Avatar
User 71024
You can ***** punch the inside of the hub then drive the races back in, that will buy you some time.
Old Oct 23, 2005 | 02:00 PM
JMR's Avatar
JMR
Red face
I think my brother has a couple layin around, I'll check it out. Much thanks!
