Franklin2 NEED HELP??
Old Oct 22, 2005 | 09:34 AM
procastnate's Avatar
procastnate
2001 F150 4.2 Still having ignition problems. The starter checked out. The battery checked out. Tester is showing a drop at all points. Today I am going to try a seperate ground to the starter?? Need to hurry a hurricane is coming!! Is it possibly my ignition switch? As soon as I put the key in all the gauges go haywire. When I turn the key all lights go out. HELP!!
Old Oct 22, 2005 | 04:44 PM
Franklin2's Avatar
Franklin2
This is a bad battery, or a bad connection at the battery cables on either end. I would disconnect and clean connections #1, #2, #3, and #4 in the diagram below.
