351M to 351W conversion... help needed
Old May 14, 2002 | 08:11 AM
eph1fifty's Avatar
eph1fifty
Hi everyone!
I'm currently looking for a mid 70's F100/F150 truck. I did see a 1977 F150 2WD that I could get but it has the usual 351M. I'm buying a 351W next weekend and it's going to be all fixed up nice
My question is can I put in a 351W into this truck? I was told that the 351M would most likely have a C6 tranny. If that's the case I'd put in a C4 (which I can get for pretty cheap also). How well would the 351M + C6 to 351W + C4 swap go? I hear that it all should just bolt in with no problems.
Or should I just continue my search and find a truck with a 302 or I6 which in this case the 351W should just bolt in.
Thanks!
Steve
Old May 14, 2002 | 10:17 AM
Fastcat's Avatar
Fastcat
You'll be better off finding a donor truck or car with a 351w to pull all the brackets and stuff. There may be some wiring issues to deal with also. You'll need cross members and motor mounts also.
Old May 14, 2002 | 11:09 AM
loudfords's Avatar
loudfords
The conversion is straightforward if you have a complete 351W with accessory brackets and transmission. This swap is easiest in a 302 truck like mine. Same motor mounts, same wiring harness, just different exhaust. Make sure to get front sump pan for the 351W. I had a 351M in my truck between the 302 and the 351W, if you have a complete donor vehicle it's just plug & play.
Old May 14, 2002 | 12:23 PM
eph1fifty's Avatar
eph1fifty
Ok thanks guys, any web site with details on such conversions?
Old May 14, 2002 | 12:39 PM
Mil1ion's Avatar
Mil1ion
You're on it right now.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 14, 2002 | 12:50 PM
77sc's Avatar
77sc
Been there, done that. It is easiest to have all accessories on the engine and have a tranny attached. You WILL have to use a tranny with the small block bolt pattern. I had a van as a donor and had to use different motor mounts for a 302 and different exhaust. The wiring was a direct plug-in(the van was a '77 also). Despite people telling me the van's center-sump oil pan wouldn't work, I measured carefully several times in several places and dropped it in with about 1-1/2" clearance between it and crossmember. Did it over a weekend and cranked it right up.
Good luck.
Kenny
Old May 14, 2002 | 01:10 PM
Mil1ion's Avatar
Mil1ion
