Dual Alts
Old Oct 21, 2005 | 02:44 PM
mjordan_mht's Avatar
mjordan_mht
Dual Alts
I have a 2005 ... how can I tell if I have 2 alts??? I see the one on top.. where would the second one be??? .... If I dont have it how hard is it to add on?
Tks
Old Oct 21, 2005 | 04:47 PM
blood's Avatar
blood
it would be at the bottom .dont waste your $ unless it is going to be used to run alot of heavyduty aux, equip,.if the dual alt,is not kept in use it will go bad fast.you are much better off with a high output alt, not to mention if you do not no what a dual alt, looks like or how to find it.just kidding around dont be upset.
Old Oct 21, 2005 | 04:59 PM
mrz50's Avatar
mrz50
If you dont have the dual option to begin with it is nearly impossible to add and if you do have it the load has no effect how long the second alt will last
Old Oct 21, 2005 | 09:49 PM
tvsjr's Avatar
tvsjr
To clarify a bit, the second alternator will be directly underneath the first... they should both be clearly visible when standing on the right side of the hood. If you can find one, you should be able to find the other if equipped.
Also, one of the pipes out of the turbo runs right by the alternators, and will have a pronounced "crimp" in it if equipped with a second alternator.
Old Oct 22, 2005 | 08:03 AM
Customz's Avatar
Customz
why would a second alt go bad?
Old Oct 24, 2005 | 01:15 PM
PSlover's Avatar
PSlover
The dual alternators share the load.
On the 05 truck with the 6.0 one alt is mounted forward of the other and uses a separate drive belt.
If you’re concerned about running a large electrical load and running the batteries down, Ford provided a (BCP) battery charge protection option. Basically there is a wire behind the fuse panel that you can hook to power through a switch or even better one of the up-fitter switches and when power is applied the engine will increase idle speed based upon battery voltage. When you turn on the switch the engine will idle up to 1200 RPM (normal voltage) and speed up to a max of 2400 RPM as the voltage drops which will keep the alt output ahead of the load or until you reach the max rated output.
Check out the following Ford SVE Bulletin for more information https://www.fleet.ford.com/truckbbas/non-html/Q108.pdf
The BCP is also a great way to quickly warm the engine on a cold day.
Old Oct 24, 2005 | 06:25 PM
blood's Avatar
blood
because if you dont use it you will lose it.i have seen many of them go bad from lack of use.
Old Oct 24, 2005 | 06:56 PM
Customz's Avatar
Customz
I was under the impression they both share the load or one cycles on and one cycles off to ensure this doesn't happen.
Old Oct 24, 2005 | 08:28 PM
Brian460's Avatar
Brian460
There is no reason a alternator would go bad from lack of use.
I suspect that there are wired directly in parallel which would cause equal load on them at all times anyways.
Old Oct 25, 2005 | 08:28 AM
mrz50's Avatar
mrz50
Just how many suuperdutys have you seen with the daul alts ??
Seams like they are a fairly uncommon option
Old Oct 25, 2005 | 09:41 AM
EPDP99's Avatar
EPDP99
I have seen alot of them. Mine has them.
Old Oct 25, 2005 | 10:18 AM
Super Steve's Avatar
Super Steve
I didn't know that applied to alternators too.
Old Oct 25, 2005 | 12:49 PM
ridered29's Avatar
ridered29
My truck has them only because they were there. Surely by not loading up the system often would the second alt. go bad. If that is the case then it would fall under the category of bad design in my opinion. Then again Ford has done a few bone-head moves!
Old Oct 25, 2005 | 01:07 PM
Shawn90yj's Avatar
Shawn90yj
I believe the snow plow prep package makes the dual alternators standard.
Old Oct 25, 2005 | 07:53 PM
mrz50's Avatar
mrz50
And how many have you seen fail due to lack of load ?
My 2000 F350 had them and so does my 05 and I have never had a problem but I did have to special order my truck as its fairly hard to find a truck on the lot with dual alts
