Thermal limiter
Old Oct 20, 2005 | 09:33 PM
James W. Hitch's Avatar
James W. Hitch
Thermal limiter
1982 F-150 Truck I am not getting as much as I use to How can I test this or does this have nothing to do with my problem
Old Oct 20, 2005 | 10:09 PM
Franklin2's Avatar
Franklin2
I hope someone else knows what you are talking about, because I haven't a clue? Whats a thermal limiter, and where is it located on the truck?
Old Oct 20, 2005 | 10:32 PM
James W. Hitch
It sits inbetween the fan and heater coil against the fire wall on passanger side of truck It has 2 coil/spring looking things
Old Oct 20, 2005 | 11:13 PM
Franklin2's Avatar
Franklin2
I think you may be talking about the motor resistor assembly. This is what gives you the different speeds on the fan blower. Here's a picture.
http://www.autozone.com/images/cds/g...3d800a74a5.gif
Old Oct 20, 2005 | 11:23 PM
James W. Hitch
Yes that is it!I was using the name thermal limiter because thats what they call it in the haynes manual.Now is there any typr of test for it?
Old Oct 20, 2005 | 11:24 PM
James W. Hitch
Thanks for the help
Old Oct 21, 2005 | 01:11 AM
Franklin2's Avatar
Franklin2
Well, if your fan blower works ok in all speeds, then it's working. It's just a resistor, so if you get continuity through the springs, it's ok.
What's the problem with the truck?
Old Oct 21, 2005 | 06:13 PM
James W. Hitch
One speed fan
Old Oct 21, 2005 | 10:29 PM
Holmesuser01's Avatar
Holmesuser01
Replace it. Easy repair
Old Oct 22, 2005 | 10:33 AM
James W. Hitch
I checked with a meter and its OK.Could it be in the switch itself?
Old Oct 22, 2005 | 10:35 AM
fordborn's Avatar
fordborn
There have been some issues with the switch on these. I had one that actually burned up 3 switches before one held. Pull the switch and look at the connections see if there is any burnt spots.
Old Oct 22, 2005 | 05:39 PM
James W. Hitch
Thanks for the help I fixed thank you for your help
Old Oct 22, 2005 | 09:56 PM
Holmesuser01
What did you do to fix it?
Old Oct 22, 2005 | 10:44 PM
James W. Hitch
cleaned contacts on thermal limiter,cleaned all contacts electrical contact cleaner,bad ground,lubed fan motor add antifrezze for heat Installed over flowcontainer. Things I should have done before asking for help
Old Oct 23, 2005 | 09:48 AM
Holmesuser01
You are set to go. One thing, did you clean the fan itself, and check to see if there is a load of crud piled up downstream of the blower fan? You'd be amazed how fine the fan can chop leaves. Its enough to clog the evaporator, if you have A/C.
If you have to clean the crud out, get a vacuum cleaner and use the crevice tool.
12gaugeCharlee
New Member Introductions
Jan 24, 2018 10:05 PM
Lawrence Taylor
Engine Swaps
Aug 5, 2017 09:33 AM
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
