Needing Answers
Old Oct 20, 2005 | 08:49 PM
havoksbak's Avatar
havoksbak
Thumbs down Needing Answers
I have a 1987 F250 utility beds, I need to know if a 351 Midland moter will mount into my 302 efi engine compartment without any major problems or changes made to my mounts.The new (to me) 351 is a 1978 model.Thank you to anyone who can advise me in this matter.
Old Oct 21, 2005 | 09:39 AM
Mike G's Avatar
Mike G
First off, welcome aboard!
Secondly, A 1978 351M will fit in the engine bay, but it will not work with anything you currently have under the hood, including the tranny....
--Mike
Old Oct 21, 2005 | 10:05 AM
ford390gashog's Avatar
ford390gashog
whats a midland engine? is that custom? or special outside the us?
Old Oct 21, 2005 | 10:16 AM
Kemicalburns's Avatar
Kemicalburns
a 351w would be a direct bolt in for your 302 and will give you the power your looken for. the 302 wiring harness and motor mounts and accessorys will all bolt to a 5.8. try and find one from 88-94 if you can . otherwise check ebay for the upper/lower efi intake from a 5.8 they are way cheap . this way you can keep efi. i did a similar swap in my bronco and never looked back.
Old Oct 29, 2005 | 09:50 PM
nevrenufhp's Avatar
nevrenufhp
I've heard the term Midland before. It's someone's answer to what a 351Modified is. To some people, there's no way you could call a stock 351M a 'Modified' engine.
Old Nov 6, 2005 | 09:49 PM
jerclark's Avatar
jerclark
Needing Answers
that would have to be what he is refering to, the 351modified. ford came up with the name simply because they needed a way to distinguish the three 351s in books and the 351m was a "modified" 400.
64custom
Feb 26, 2014 09:45 PM
Granny Gear
16
Jun 24, 2012 07:25 PM
tsi9973
Apr 27, 2006 05:43 PM
poorfolks
Engine Swaps
Aug 17, 2004 10:31 AM
poorfolks
Aug 16, 2004 09:25 PM
