gear ratios
Old Oct 20, 2005 | 12:38 PM
77bigblock's Avatar
77bigblock
gear ratios
I have a 77 F250, C6, 460, Dana 61 with 3.31 gears. I occasionally pull up t0 7,000 lbs with it. I know that the gearing isn't the best for towing. Am I going to hurt the rear end by pulling that much with it or hurt any other components?
Thanks for the opinions.
Old Oct 21, 2005 | 07:46 AM
jowilker's Avatar
jowilker
No Sir, I pull that weight with a 3.00. Just make sure the fluid level in it is ok.
John
Old Oct 21, 2005 | 08:01 AM
BFR250SD's Avatar
BFR250SD
Doesn't hurt the rearend. The biggest component that takes abuse from high gearing is the transmission. It puts a killing on autos and it puts a hurt on clutches too. Not sure what the ratio is in your C6, but that has a lot to do with it as well. Sometimes the gearing in the trans can cope with it.
Old Oct 21, 2005 | 05:41 PM
77bigblock's Avatar
77bigblock
I have a shift kit and a 2000 rpm stall on the transmission, so it is built to take some abuse. So form what you guys tell me, I should be ok.
Old Oct 22, 2005 | 07:48 AM
Ford Truck Racer's Avatar
Ford Truck Racer
Your trans has a 1.1 high gear, so you would have a 3.31 final ratio which ain't bad for towing that weight. The only thing I would recommend is an extra tranny cooler than the factory one.
Old Oct 26, 2005 | 08:58 PM
AerostarTrailHiker's Avatar
AerostarTrailHiker
You should be ok. Just keep up on the regular maintenance.
