freeze plugs
Old Oct 19, 2005 | 10:04 PM
mechanix_62454's Avatar
mechanix_62454
Question freeze plugs
Hey yall, I need help...my truck leaks water and I was wondering how to go about changing the freeze plugs(atleast I think thats what the problem is) on the side of the block..should I A. drop motor mounts and lean the motor or B. pull the motor? I aint exactly a skinny guy so I have problems reaching down into the engine compartment and aroudn the exhaust and hoses
Old Oct 19, 2005 | 10:08 PM
ford390gashog's Avatar
ford390gashog
well pulling it is easy so i would go that way. also if you have any oil leaks you can install a gasket set with the engine out should be about 55.00 for gasket set and plug set.
Old Oct 24, 2005 | 03:01 AM
mechanix_62454
cool, thanks
