Need data label decoded
Old Dec 2, 2005 | 06:08 PM
springirl's Avatar
springirl
hey, i looked up the factory specs for your springs are part # 43-569 which came as a 4(leaves of .291 material)/1(l bottom leaf of .625 material) =5 leaf spring with 5/8 5.0 bolts @ front and 9/16 5.0 bolts @ back. 3" wide. hope that helps, new ones retail for $141 each and $148 for 6 leafers. D
Old Dec 5, 2005 | 01:40 PM
1975Ford's Avatar
1975Ford
springir, I have heard the leaf spring off a 198* ish Bronco would fit. I like the leaf springs off those 1980 ish broncos because, they have the black plastic spaces between the leaf spring pack. Would any of those leaf springs fit?
Old Dec 5, 2005 | 09:16 PM
1986_F150's Avatar
1986_F150
they should fit it cause the frames of the 80's pickups and broncos are the same
Old Dec 7, 2005 | 07:10 AM
springirl's Avatar
springirl
i'll check to see if the front bolt is 5/8 or 9/16 at work today
Old Dec 7, 2005 | 07:30 PM
springirl's Avatar
springirl
hey bronco springs are 3" wide 25/31 length measureing along the inside of the main leaf with 5/8 in front and 9/16 in back for 5.0 gr 8 bolts. so as long as the length is the same go for it
Old Dec 12, 2005 | 09:07 AM
1975Ford's Avatar
1975Ford
Thanks, I will check the length.
bossmaverick
15
Jul 7, 2016 07:20 PM
Dave588
Large Truck
Jun 4, 2016 11:20 AM
Will237
1947 and Older Ford Trucks
Apr 4, 2016 12:35 PM
Gary Lewis
40
Jan 22, 2016 05:50 PM
