Clutch replace???
Old Oct 18, 2005 | 08:57 PM
longpoleman's Avatar
longpoleman
Clutch replace???
1996 F150 6cvl 4x4 5 speed about 156,000 miles
How can I tell if my clutch needs replacing?
I bought the truck used in 1997. I have never replaced the clutch in the truck. However I have replaced the slave cylinder twice. How long should a clutch last? is mine due for replacing. It feels like i have to push the clutch pedal alot further down to get the clutch to engage. Today it was hard to get into reverse. I checked the fluid in the master cylinder and it was good. I practiced shifting without the clutch on the way home from work today just in case. Is there a way of adjusting the clutch? If i need to replace it how bad of a job is it. Is it something that I could do myself with a manual of some kind? I am confident that I can remove the trany just fine its what comes next and alinging it back up in the truck that scares me. Any help thoughts or opinions would be greatly appreciated.
Thanks
steve
Old Oct 19, 2005 | 05:42 PM
andym's Avatar
andym
How long the clutch lasts depends on how you drive it. I've seen people get 30k out of one, and I've seen 250k on an original clutch.
When they need to be replaced, they start slipping. When you have it in overdrive at around 2000, hammer the gas. If the RPMs increase out of proportion with the speed, then it's slipping. That's the easiest way to tell.
Also, when one of these trannies needs a clutch, I have found that they are harder to get into 1st and reverse.
Replacing one is a job, especially if it's a 4x4. You have to slide the tranny back far enough to get all the parts out (clutch disc, pressure plate, throwout bearing, pilot bearing, and flywheel).
It's definitely a two man job, preferably with someone who's done one before.
Old Oct 19, 2005 | 09:27 PM
longpoleman
I dont have a tach on the truck so i will try to guess about 2000rpm and give your test a try. Today the distance of pedal travel toe ingage/disingage the truck shrank some more. The truck will not go into reverse unless I first go to another gear than slam it back into reverse. What suprises me is that it has happened in a matter of just a few days. This makes me wonder if there is something else causing this problem.
When changing the clutch, would it be easier to just remove the whole trany than reinstall it? Also do I need a realignment tool? Can you point me in the right direction to an almost step by step instruction manual? I do have a friend who says he has done this before. He offered to let me bring it over and he would help. I would like to read up on it first to know a little more about whats going on incase he makes a mistake.
Old Oct 20, 2005 | 01:13 PM
andym's Avatar
andym
It's not that much more work to remove the whole tranny, as long as you have it up in the air. If you are working on it on the ground, then you won't be able to take the tranny out.
The alignment tool comes with a clutch kit. It's just a plastic doodad that hold the disc in place while you're tightening down the pressure plate.
The closest thing to step by step instructions are going to be in a chiltons and/or a haynes manual. Buy both, and read the clutch section in each. You should have a good idea of what to do.
Old Oct 20, 2005 | 07:44 PM
longpoleman
removing the trany on the ground cant be done or is difficult. What about having it up on jack stands? To me, it seems that it would be a real pain in the but to try to replace the clutch under the truck with the trany just slid back, but then again your the experts. I have never changed a clutch before.
