Need some help here.
Old Oct 18, 2005 | 10:07 AM
t1texx's Avatar
t1texx
This is another cruise control problem on a 96 F350. I have tested all the fuses and relays and they all seem to be fine. I have no power at the Pressure switch on the master cylinder. Does anyone have a wiring diagram that shows colors and voltages for this circuit and where to test to verify where the fault might be.
Frustration limit is high on this one!!!!
Old Oct 18, 2005 | 10:12 AM
barebackjake's Avatar
barebackjake
i can shoot it over to you tonight i dont have my disc with me right now. if you fill out your sig it will help too. you have a manual or auto?
Old Oct 18, 2005 | 10:26 AM
t1texx's Avatar
t1texx
That would be great. Signature should be showing up now. Thanks for the help!!! It is an automatic btw.
Old Oct 18, 2005 | 10:31 AM
barebackjake
ok that eliminates that idea. ive had my clutch switch cause cruise probs a couple times. i would check to make sure your brake lights work i know someones cruise stopped working when they had a lamp burnout in there truck.
Old Oct 18, 2005 | 10:37 AM
t1texx's Avatar
t1texx
All the tail lights/break lights work. No issues there.
Old Oct 18, 2005 | 07:32 PM
t1texx's Avatar
t1texx
replaced the speed control pressure switch at the front of the master cylinder. I check voltage with the key off and had nothing. I checked the voltage with the key on and got 12V. Relays all test good and all fuses are good. What now?
