Intercooler, propane or methanol ?
Old Oct 18, 2005 | 07:11 AM
deanj's Avatar
deanj
Maybe adding one of the above to one of the 350's (94/TD, dually - ats flange pipe and exhaust, pump turned up, timming 8.5) From what I have been reading, a intercooler is not that effective if U are running less than 12-15 lbs boost. I am running around 6-7 @ 2400, ET's 650. Propane - ats seems to think it is not worth it. Methanol - windshield washer fluid - has anyone had any experiance? All imput would be appreciated.
Old Oct 18, 2005 | 11:05 AM
justblowin'smoke's Avatar
justblowin'smoke
i'd adjust the wastegate for 12-15 psi of boost and put a intercooler on it thats what im planning on doing
Old Oct 18, 2005 | 11:27 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Go with an aftercooler, they work much better than an intercooler and there is no need to refill them when they go empty .
Just my $.02
Old Oct 18, 2005 | 05:36 PM
deanj's Avatar
deanj
The actuator rod it "turned in" all the way, and only 11-12 # at hard acceleration. You will be lucky to see anymore than 12 on a stock turbo. Plus if you start getting into the 15 + I would be looking at replacing the head bolts with sronger studs
Old Oct 18, 2005 | 08:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Do you still have the stock intake snorkel that sits over the drivers side battery?
A little work to get ram air from the grill area will help it out.
I am going intercooler if I ever get my reman junk engine straightened out.
Old Oct 18, 2005 | 10:08 PM
deanj's Avatar
deanj
That was modified way back when. If you are running CONSTANT boost of at least 12# I can see the intercooler but ant less????
