plumbing help, please
Old Oct 18, 2005 | 05:12 AM
slifer's Avatar
slifer
How do you join a copper pipe to cpvc? I have a 1/2" copper pipe (hot water supply) that went into a 1/2" cpvc stop valve which sprung a leak at the connection. Would cpvc cement work on a copper to cpvc joint? Thanks
Old Oct 18, 2005 | 05:29 AM
MrOldV8's Avatar
MrOldV8
Sweat a threaded copper coupling to the copper pipe...
Screw a threaded plastic coupling to the copper coupling...
Glue the plastic pipe to it.
MR
Old Oct 18, 2005 | 12:33 PM
slifer's Avatar
slifer
I didnt think it seemed right to have them just glued together like they were, but wasn't sure. I appreciate your help.
Old Oct 18, 2005 | 01:10 PM
e1p1's Avatar
e1p1
Don't know if this still holds, but 20 yrs ago when joining PVC to metal (I was installing hot tubs), you wanted to use a female PVC threaded fitting over a male metal threaded fitting.
Reason was if the water gets too hot the metal expands, and the PVC shrinks, and the seal will only get tighter. Do it the opposite way and a female metal fitting might expand while the PVC contracts, and you spring a leak.
Old Oct 18, 2005 | 02:24 PM
slifer's Avatar
slifer
That makes sense, I'll remember that, thanks.
Old Oct 18, 2005 | 04:31 PM
lenny1carl's Avatar
lenny1carl
as to the last post, thats why you need to use CPVC fittings. they are for hot or cold h2o. PVC won't tolererate hot h2o cpvc is is cream color, pvc is white. you need to use a good primer/cleaner & cpvc or multipurpose cement/ cpvc cement is orange
Old Oct 18, 2005 | 09:49 PM
DeckedoutF150's Avatar
DeckedoutF150
they make a compression fitting called quest or pex. they sell them at lowes around here and some plumbing supplu places. Huges plumbing supply has some neat new ones called sharkbite. you simply just press them onto the new pipe. either one of those will work fine and save you alot of time and work just as well. we use them alot for water leaks at the apartment complex i work for.
Old Oct 19, 2005 | 12:03 AM
barry e's Avatar
barry e
plumbing
go to local plumbing supply house& ask for a"sharkbite" coupiling 1/2" to1/2" . they work great ,just snap together ,no glue, no sweating , no fuss. barry
freirefishing
17
Nov 10, 2007 06:54 PM
Bruker
Aug 15, 2005 11:30 PM
websthes
13
Apr 2, 2005 06:22 PM
ivanribic
Feb 15, 2005 11:10 PM
73highboy4x4
23
Jun 30, 2004 06:07 PM
