Fuse block?
Old Oct 17, 2005 | 08:22 PM
MO51's Avatar
MO51
Fuse block?
I am wiring trailer lighting on a tow vehicle, using a direct battery feed via 10 guage wire and a 30 amp circuit breaker. My local Kragens doesn't seem to stock a fuse block gizmo that will give me power from the 10 guage wire for 4 fused/relay circuits. Their "fuse block" doesn't include a power strip to all 4 circuits. I'm in Sacramento. Any tips on who has this item, retail or on line? Maybe Radio Shack? Thanks.
Old Oct 18, 2005 | 06:40 AM
subford's Avatar
subford
As far as I can tell Kragens is some kind of an auto parts store, never heard of them.
So I would try an RV parts store.
Old Oct 18, 2005 | 11:40 AM
Franklin2's Avatar
Franklin2
If you can't find anything, you can jump them all together on one side. If you are going to run approx 15 amp circuits or smaller, you can take the big yellow fork connectors, take two 14 gauge wires and insert them into one connector. Use these to jump across the fuse block.
