help with 390 stalling after started
Old Oct 17, 2005 | 08:18 PM
7sixf150's Avatar
7sixf150
how do i fix this? it starts good. but then after a few minutes it will stall. do i need new choke lines? or is there more to it?
Old Oct 17, 2005 | 08:52 PM
fordeverpower's Avatar
fordeverpower
my guess is that the choke plate on the carb is staying closed as the motor warms up. I don't know it could be a fuel problem, since it restarts, right?
Old Oct 17, 2005 | 08:55 PM
7sixf150's Avatar
7sixf150
i also don't have the choke lines hooked up. both of them broke off. does anyone know how to put new ones on?
Old Oct 17, 2005 | 09:04 PM
fordeverpower
wait a minute, where do these choke lines come from, the manifold or exhaust manifolds? I smell an imposter! lol
Old Oct 17, 2005 | 09:05 PM
7sixf150's Avatar
7sixf150
exhaust manifold i'm pretty sure.
Old Oct 17, 2005 | 09:23 PM
fordeverpower
try a an elcetric choke setup, I never heard of FE's having an automatic type choke.
So does the choke plate move at all?, the throttle plate or whatever you refer to it as.
Old Oct 17, 2005 | 09:25 PM
7sixf150's Avatar
7sixf150
i'm not sure if it moves. i will check in the light tomorrow though. how do i set up an electric setup?
Old Oct 17, 2005 | 09:35 PM
jd_sylvia's Avatar
jd_sylvia
I'm a control freak so I like my manual choke myself. I had a simular problem and the bowl level were just set way to low. That was on a Motorcraft Carb.
jd
Old Oct 17, 2005 | 09:40 PM
76supercab2's Avatar
76supercab2
Few things to check.
1. Fast idle speed. Should be 950-1000 RPM
2. Choke pull off. There's a vacuum dashpot that should pull the choke plate slightly open after it starts. Check by taking the air cleaner lit off, set the choke and start the truck. As soon as the engine starts, you should see the choke plate move maybe 1/8 inch.
3. Choke plate adjustment. There should be just enough spring pressure to close the choke plate.
Old Oct 17, 2005 | 09:44 PM
7sixf150's Avatar
7sixf150
ok thanks. i also have a 4 bbl holley carb if that changes anything?
Old Oct 19, 2005 | 05:39 PM
1975Ford's Avatar
1975Ford
Choke operation is basically the same, with manual and electrical choke, on a four barrels or two barrel or one barrels.
Convert the choke to and electrical housing choke and run the positive wire from the alternator terminal. Not quite sure if it was the stator side on the alternator. But it should pull 7.5 volts if it is the right terminal on the alternator.
roree
Jan 7, 2010 12:49 PM
powerfarmer
35
Jan 25, 2008 07:24 PM
Rich Wood
May 12, 2007 04:24 PM
57chevybmwz3
New Member Introductions
Dec 13, 2004 05:13 PM
