Finally Registered!! Now I have a question!!
After many months of enjoying this site I figured I better register. It is a great help for backyard mechanics like me. My question is concerns a 1983 4.9L f150.
The charging system is only putting out only 11 to 12 volts which drains the battery after a week or so. I suspect the voltage regulator.(The battery and alternator are new-- didn't remedy the problem but both where ancient anyway.)The regulator is the type mounted in the engine area above the passenger wheel well. I know there is a way to check it by measuring the voltage across a combination of the tabs but I forget which combination it is. Any help would be appreciated...Thanks!!
on
1 Post
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
Thread moved to 80-86 F-series forum.
See ya on the boards!
-Matt
-Matt
