noticed the 1988 efi 460 dist,had part# e7 while the dist for 1990 460efi had the casting starting with FO,,,they both have the remote fender ignition module,can they both be used in either block? noticed the 88 dist,had a thicker
base (sideview)above the gear about an inch or two,i think thats where most distributors for the 460 seem to get seized in the blocks,and the newer 90's had a thinner base about by four millimeters,,other than that they look the same
