[updated:LAST EDITED ON 18-Mar-02 AT 11:36 PM (EST)]I am looking to upgrade my ignition because it is all original, and I figure with a new engine I might as well throw on a new ignition. Plus the engine rebuilder said that he would have liked to see a new distributor in the engine.
I've heard the MSD 6a is a good control box, good price, found it for $150.
I also found a MSD Blaster 2 coil for $37, so far so good.
Now what about distributors, shouldn't I stay with vaccuum advance on my mild M motor? Keep in mind that I will be upping the power later on (few years), pistons, 4bbl, 400 conversion, already got duals etc. The MSD 8580 is cheap at $190, but doesn't have the vaccuum advance. The MSD 8447 and 8350 (Pro-billets) have vaccuum but are $260 and $286 respectively. The mallory vaccuum assisted ones are a bit cheaper ($200ish), BUT will they match up well/connect with the MSD stuff? Any cheaper/better alternatives?
Can I upgrade piece by piece? (I would like to add control box and coil first, then distributor OR VICE VERSA.
weldman, congrats on the new engine. Many people like the MSD stuff, and it is compatable with the Duraspark distributor. All you need to hook it up is a wiring harness that adapts the box to the DS distributor (MSD sells it).
Both MSD and DuraSpark are magnetic triggered systems. The Mallory is an infrared light triggered system (Unilite), and is not compatable with the MSD or DS.
That being said, my favorite is still the 'ol DuraSpark. It has a "timing retard upon starting" feature that I like, and has been very reliable for me. A hotter coil, and low resistance plug wires is all you really need with the DS. It is really a trade-off, in whether you like the multiple sparks from the MSD (up to 3000 rpm), or the spark retard from the DS.
If this is a street driven engine, you really need the vacuum advance. It will give you better mpg, and I don't need to say how important that is.....
Ok, next question, what am I going to notice with an MSD 8447 as opposed to my DuraSpark? Will it not start as well? (I don't understand what the retard feature does.) Isn't it the MSD control box that provides the multiple sparks, not the distributor?
I would like to upgrade the factory coil and ignition box, and the MSD components seem to be the way to go from what you are describing.
Where do I find a stock replacement distributor if this is the way to go? How much should I expect to pay? Aren't I going to get better performance from the MSD 8447, or is the extra cost not going to be worth it?
I am running the complete MSD igntion system on my 390. The only problem you will have in componant matching is that you must have the MSD box to run the MSD distributer. Of jcourse since my distributor upgrade it starts and runds alot better (woldn't have changed it if I wasn't having problems) and it gave a nice racey sound to the engine. The MSD system is also "VERY SIMPLE" to install.
Yes, some of the dizzy's say that they require the 6A box, which is ok, since I want the box anyway.
Due to the high cost of the MSD distributors, the parts guy at the speed shop has pointed me to an Accel 9203, which was almost half the price! It is supposed to be a stock replacement for the Duraspark. Anyone have any comments on this?
I think that Mallory does make a few magnetically controlled distributors, won't they work with the MSD box like the Duraspark and the replacement above are supposed to?
Weldman, sorry I wasn't clear on the boxes. Yes, the MSD box is what gives the multi-sparks. The DuraSpark box has a timing retard feature that automatically retards the timing about 2 degrees when the starter is turning. This gives a quicker start, and eases the load on the starter. When the starter disengages, the timing is advanced normally.
MSD sells a wiring harness (MSD-8869, $15.50) which allows a MSD box to connect to the stock DS distributor. This is a plug-in install, with no wire splicing. Later on, you can easily install a MSD distributor, if you want. You can use any aftermarket coil of your choosing, with either system.
You can get a rebuilt DS distributor at any auto parts store. Cost should be in the $60-70 range.
Weld, the Accel is a rebuilt, blueprinted distributor built on the DuraSpark core; so yes, it should be similiar to the stock DS dist, with the same wiring connectors.
I can't comment on the magnetic pick-up Mallorys. I thought they were all light-triggered (Unilites).
[updated:LAST EDITED ON 20-Mar-02 AT 01:12 AM (EST)]Mallory makes a 57 and 85 series.
The 57 is a magnetic breakerless vac advance #5756701 - its out, just as expensive as MSD's. The 85 is a magnetic vac advance stock replacement with stock connectors #8556701. The two are on the Mallory website (distributorsM.pdf). Whats the difference between the two?
edit- the 85 and 57 series are the same price on the racesearch (260-290) Guess their out too!
Which one should I choose, accel or a rebuilt NAPA etc?
[updated:LAST EDITED ON 20-Mar-02 AT 02:00 AM (EST)]Just checked the Accel 9205, more my style at $126. Would there be any difference between the accel and noname rebuilt one? Is the accel worth the extra $60?
There is also a 59205 which is a high performance replacement at $213. Worth it? Narrowed it down to these 3 finally!
Also, found an accel 8140C coil, 42,000volts compared to the MSD 45,000. Will I notice any difference? I mainly want the accel for the chrome look.
I know who cares about my two cents, but a lot of folks are looking for those old durafartII distributers due to ease and realiability. Folks meaning those younger computer controlled folk resorting to the glory of the carb. If it aint broke don't fix it...
Yeah, tetraruby, and the DS is also a popular conversion with the 64-71 Mustang crowd. I like the DS.
Weld, you won't be able to tell the difference between the 42Kv and the 45Kv coils. These are peak output ratings, and I'm not sure how accurate they are anyway. If you want the shine, go with the chrome.
Glad you made a choice. Sorry, didn't mean to offend your upgrade efforts - I know the reasoning. From my own experience everytime I try something over and beyond it seems like more trouble for what it's worth. Hold on to that old, worn distributer...let us know how the install / and results go.
