Need help with this idea
Old Oct 17, 2005 | 08:23 AM
thunderguns71's Avatar
thunderguns71
Im sure some of you remember awhile back I was working on a 352 that had mis-matched heads etc on it. Well I put on a set of exhaust ported C4's , and done things like new gaskets, oil pump, and used the cast iron manifold back on it , with the I guess stock cam. Im not building this for mysefl but anyways, I plan on changing the cam and intake, so what do you guys recommend to give me quite a bit more go. I plan on changing over to headers also. The vehicle is geared 3.50 and its does alrite just runs out of breath with the manifolds and isnt that peppy off the line. Also would going to a pertronix unit hurt any?
Old Oct 17, 2005 | 11:56 AM
rusty70f100's Avatar
rusty70f100
Well, since the heads are off of it, now would be the perfect time to measure the deck clearance. This will give us a rough idea of what compression this thing will have, and allow us to give a good cam recommendation.
Oh, and on the intake, go Performer RPM.
On the ignition, I like the Mallory Unilite distributor that I'm using. When installed correctly and their active power filter is used, it is very reliable. It does cost more than the Pertronix, but I feel it's worth it.
Old Oct 17, 2005 | 04:41 PM
thunderguns71
I think you read me wrong, the heads are back on it, it is currently running in the car. Its a 352 rotating assemble in a C6ME block, with c4ae heads. And the pistons are flatops with "no" vavle releifs or dish.
Old Oct 17, 2005 | 04:53 PM
rusty70f100
Aha! Do you remember a part number, or the manufacturer? I can probably dig up some specs on 'em. Also, what head gasket did you use?
Old Oct 17, 2005 | 08:15 PM
thunderguns71
Used fel-pro FEL-8554PT which is supposed 2 be OEM gaskets. I didnt pull the pistons and im pretty sure they are stock pistons though.
Old Oct 17, 2005 | 08:25 PM
chevy tow truck's Avatar
chevy tow truck
the 3.50 has to go and a 3.73:1 needs to go in with a thick shime on the cluch pack to help kick the poss. track in sooner. the 3.73:1 will give your the punch off the line. the thick shimes will make the meat grabb the street
you can get in the 2001 lighings to present.
Old Oct 17, 2005 | 08:30 PM
rusty70f100
Well, I think your compression will be somewhere around 9:1. That's with the emphasis on "somewhere around".
There are two cams that would work, either the Crane 343901 or the Crane 343941. Use the 901 for more low end torque, and the 941 for more top end HP.
Old Oct 17, 2005 | 08:47 PM
fordeverpower's Avatar
fordeverpower
yeah, the rpm intake seems to do well. I 'd rather a MR blue thunder piece though.
Rusty has it on the cams, btw i have spun the 901 powered 390 about 5700 rpm.
Old Oct 17, 2005 | 08:56 PM
thunderguns71
Id probably use the 901 then, the 3.50 gears is probably all it will ever get. Ofcourse it would help if it was 4 speed, but i guess an automatic will do.
Old Oct 17, 2005 | 09:00 PM
fordeverpower
Same here, its all i got in my 5200lb truck.
Old Oct 17, 2005 | 09:14 PM
fordeverpower
Thunderguns71, i hope you are not using stock springs. I have tested 5 or 6 sets of STOCK fe springs and they are completely solid at 1.250-1.270.
With a 1.82 installed height minus .524 for 1.73 ratio exhaust lift euals 1.296. Then the absolute mininum clearence is .060 before coil bind. 1.296-.060 is 1.236.
Now I have run the 343901 on stock springs but the installed heights were way off, 1.900 range. There was no shims, they were setup, no wait they weren't setup by the previous builder.
Spend the $64 for the 99837 springs or whatever the new recommeded springs are.
Old Oct 17, 2005 | 09:37 PM
thunderguns71
Ok, thanks for the spring tip
Old Oct 17, 2005 | 09:46 PM
rusty70f100
Here's a link to Crane's online cam card for the 343901.
They recommend their 96801 springs. They used to recommend the 99837 springs.
Old Oct 18, 2005 | 01:11 AM
fordeverpower
thats interesting Kurt, The seat pressure is up when the open is down. Must be less spring rate. whats the purpose of that?
Old Oct 18, 2005 | 12:19 PM
rusty70f100
I dont know. Maybe they were having problems with lifter spinning, or wiping cam lobes? Whatever it was, it doesn't sound too promising for those of us running the 99837 springs, myself included.
