1973 F250 specs
Old May 16, 2021 | 09:59 AM
sbilby123's Avatar
sbilby123
Thank you. Changing oil today to diesel oil t4 today
Old Jul 8, 2021 | 08:39 AM
sbilby123's Avatar
sbilby123
shocks. 1973 Ford F-250 Custom
have a 1973 Ford F-250 Custom Styleside Shocks seem to be original. What would proper shocks be to replace them? and are the front shocks the same as the rear? 6200 GVW. Thanks!
Old Jul 8, 2021 | 11:17 AM
redroad's Avatar
redroad
Welcome to FTE !
with 360 motor look here
Old Jul 8, 2021 | 01:03 PM
sbilby123's Avatar
sbilby123
Thank you. How can I be sure it is a Camper Special or just an F-250. 360 ? It came with a camper cap only and sat in a pole barn for 30 yrs
Old Jul 8, 2021 | 05:26 PM
redroad's Avatar
redroad
The 360 is a motor size in cubic inches. Have a look over on Rich's page he has a lot of info stashed there including your specs but you'll need to scroll through it. Go here
Old Jul 8, 2021 | 05:29 PM
sbilby123's Avatar
sbilby123
will take a look. thanks again
Old Jul 8, 2021 | 05:46 PM
redroad's Avatar
redroad
More info here and here.
Old Jul 12, 2021 | 11:13 AM
sbilby123's Avatar
sbilby123
if i'm reading the link you sent me, it looks like KYB 344071 Excel-G. for front and KYB 344272 Excel-g for rear would be proper for 1973 Ford F-250 Custom with RWD. Would you agree? thanks again
Old Jul 12, 2021 | 11:28 AM
redroad's Avatar
redroad
That is correct and to get a 5% discount if you are ordering from Rockauto go here to get the discount code. Then apply it at checkout.v
Old Jul 12, 2021 | 11:43 AM
sbilby123's Avatar
sbilby123
thank you!! ordering now. appreciate your help!
Old Aug 18, 2021 | 01:16 PM
sbilby123's Avatar
sbilby123
I have a 1973 FORD F-250 Dentside with a 360 ci V8. The original carb was replaced and seems to have some issues. What would be a proper Edelbrock carb replacement ? It has a 4-speed Warner Manual Trans paired with a 3.54 Dana 60 conventional rear axel. Thank you
Old Aug 18, 2021 | 01:48 PM
redroad's Avatar
redroad
Does your 360 have a 4 barrel or 2 barrel intake manifold ?
Old Aug 18, 2021 | 02:06 PM
  #28
sbilby123's Avatar
sbilby123
it is a 2 barrel
Old Aug 18, 2021 | 02:25 PM
  #29
redroad's Avatar
redroad
So you probably have a Motorcraft 2100 2 barrel carb on it now. There's really nothing wrong with that carb except they wear in a few places causing unwanted vacuum leaks but that can be repaired. If your truck is not your daily driver I would consider sending out your current carb to a reputable rebuilder and have it professionally rebuilt. Or if you're feeling frisky rebuild it yourself. These carbs are not overly complicated.Otherwise a holley 2 barrel is a good replacement choice.
Old Aug 18, 2021 | 02:56 PM
  #30
sbilby123's Avatar
sbilby123
Thank you very much
