I am looking at getting a super duty 2000-2003. Either a 250 or 350 PSD and don't know what the diff between the 2 are, like brakes, suspension or ride qualities. My son has a 2000 250 PSD so I have that reference
There is no difference other than GVWR on them. Same springs, brakes, seats, carpet and all that good stuff till' ya get to the dullie and you get more leafs in the rear.
the '05s and '06s are different than the earlier models. at the top of this forum is a sticky that says "read first" all the info you want is in that thread
Can you guys educate me?
Thanks
Jerry
I have a 2002 F-350 Lariat 4x4
I bought it used a few months ago and I am very happy with it.
I wanted a 1999-2003 with the 7.3 PowerStroke vs the newer 6.0
I have an automatic transmission with the 4R100
I didn't see much of a price difference for a 250 S/D vs a 350 SD when I started comparing features and such.
My truck has an added helper leaf spring that most 250's do not have
pretty much all 250/350's have Trailer/tow package on them
I paid $26K for a loaded Supercab lariat(leather seats)long bed with 79K and a 2 yr ext warranty(Ford ESP)
Larger frame cross sections on the 250 / 350
The rear axle size: 250 - 1.50" (6200 lbs) vs. 350 - 1.57" (7280 lbs)
The spline count on the rear axles: 250 - 35 vs. 350 - 37
With 4.30 gears you get the Super 60 front axle
Slightly different approach / departure angles
Got tired of looking at numbers!
What are the larger frame cross sections? Isn't it only applicable for the "chassis cab" or am I looking at something different?
Okay, somewhat along this thread...I've a '99 F350 DRW. A few leafs were broken on the driver's side last year so when they were replace I had an extra leaf added to both sides. Sets level side to side but now I'm getting the nose sag. Anyway I installed a gooseneck hitch last week and am getting a trailer ready to pull the horses around in. The problem is that the bed of the truck is too high and the trailer is at an angle that most of the load is on the back tandem axle. My question: can I remove the blocks under the springs to lower the back end of the truck? (I cannot shorten the gooeneck tube as the trailer will run the top of the bed) Or will I run into problems with drive shaft angle or anything else? Yes I know that I'll probably need new u-bolts. Can the blocks be machined down some and then replaced?
