radiator help!
Old Oct 16, 2005 | 06:17 PM
wolfe1104's Avatar
wolfe1104
radiator help!
I have a 96 e150 with a 5.8 L. i recently replaced the radiator due to several leaks. on the bottom of the radiator there was the usual tranny lines, lower hose. and then another soft rubber hose. and when i took it off the smaller hose had a light brown fluid in it. i wasnt sure what it was though. it was a few days before i was able to replace the radiator. now that i have put it in and was burrping it i started hearing a whinning noise but i couldnt tell from what. i was wondering if anybody knew what that hose was from and if that would have anything to do with it.
Old Oct 16, 2005 | 08:37 PM
RL_F150's Avatar
RL_F150
Perhaps that small hose was from the power steering cooler? A quick check of the power steering fluid should tell you if that's it.
That's the only thing I can come up with.
