I believe the salesman mentioned (although I didn't care that much, thus I didn't think to question him one way, or another) said that it had an oil cooler. (???)
I guess the best way to check is to find a line that goes from the transmission to the radiator somewhere. That would answer it fer sure.
After searching for a while, I think I found it. small tubes coming from the passenger side of the transmission up to right below the radiator to a mini radiator. It is really hidden. Behind that is the a/c 'radiator' ... that worked. I couldn't find my invoice to look at the sticker...Is the stock cooler sufficient enough to cool the transmission driving hard in the mountains fully loaded?
