blown pcm fuse
Old Oct 16, 2005 | 01:41 PM
carsuk1's Avatar
carsuk1
blown pcm fuse
i have a 96 e250 that just suddenly died so i messed with it a bit and found the pcm fuse under the hood was blown does anyone know what would cause this i havent tried to replace it yet i wanted to get some input before i get into it thanks Bill
Old Oct 16, 2005 | 04:18 PM
MustangGT221's Avatar
MustangGT221
Well, that fuse blew for the same reason any fuse blows, too much current overheating the wire. You'll have to check the wiring for a ground short or connection problem...
Old Oct 16, 2005 | 05:19 PM
Bob Ayers's Avatar
Bob Ayers
Best case a wiring short to GND, worse case, something internal to the PCM shorted to GND.
Old Oct 17, 2005 | 09:56 AM
carsuk1's Avatar
carsuk1
can anyone tell me where the cpm is located thanks
Old Oct 17, 2005 | 05:10 PM
MustangGT221
I assume "cpm" is meant to be PCM, or the vehicle's engine computer?
It's in the firewall, on the drivers side, down under the brake master cylinder. You'll see 3 or so big wire connectors going into the firewall. The one closest to the fender is the computer's plug. The computer sits in a little cubby in the firewall.
Awitte58
28
Jan 1, 2016 09:57 PM
cdev
Nov 20, 2015 10:37 PM
smash fascism
Apr 24, 2014 10:53 AM
MR5x5
Mar 22, 2014 09:25 PM
CRAZYC123
Aug 26, 2011 10:02 PM
