I've got to go with mrxlh on this one; go with a TIG / stick combo especially if you want to do a fair amount of stainless or aluminum. Then use the stick for heavier steel the TIG won't handle. We have used our MIG for AL & SS but with the TIG you have such better control of your amperage which yields better quality (structurally and cosmetically) welds. If not in a production situation, I prefer the TIG for AL and SS and I've welded lots of 1/4" and 3/8" aluminum with the TIG. On aluminum you can get the proper weld penetration more consistently and easier with the TIG.
A lot of people mistakenly believe that TIG welding is only for lighter gauge material: it's certainly one of the top methods for thinner gauge but it's very useful for heavier stuff too.
So true to weld heavy material with Tig as long as you have the power or amperage to do it. Aluminum takes alot of current, that's why I chose a 350 Synchrowave over a 250.
.....=o&o>.....
.....=o&o>.....
Yep,
Seems to me about 175 on 1/4" aluminum. We have a Hobart Tigwave 250 with a Miller watercooler.
FLGargoyle: TIG is excellent for bodywork. You will need small electrodes and collets - not a lot of extra expense. You can get special filler rod for TIG welding mild steel. It gives a much cleaner weld than regular oxy/acet. filler rod. If you will only be welding the light stuff you can get by with an air-cooled torch which will save you a lot of $$$.
Air cooled torch will be smaller, you can get into tighter spaces. I run a DW 20 torch with long tungsten and cap. Been told Mig welds on auto sheetmetal is alot harder than welds with Tig to file or grind down.
.....=o&o>.....
Correction, the air cooled torch is bigger, not smaller. Also FL, for body panels and light sheetmetal, I use .030 or .035 mig wire off of 1# spools. You can cut it any length you want and it straightens real easy. Mig wire and tig wire for mild steel should be ER70S. For stainless should be 309, while 309 is a touch more expensive than 308, 309 can be used for joining stainless to steel by AWS standards, 308 may not. I also use 309 in 1# spools. Aluminum I highly recomend 5356 over the 4043. While 4043 flows a little better, it is produces a weaker weld. 4043 works better for a root pass on cast alum, it pulls the trash out of the cast (oil and greas that is trapped) better, then grind or buff it up and use 5356 out from there. For body work I would recomend 1/16 tungsten. Steel or Stainless use 2% thoriated (red on the end) for alum use pure tungsten (green on the end) One other trick that works well for aluminum is use the biggest cup you can and turn your gas up to about 25-30 CFH and DO NOT pull your filler rod out of the shielding gas, keep it as close to the cup or below the cup as possible.
A great bit of information posted above, I used a air cooled torch that was smaller but alot lower in amperage, (apples / oranges ). To compare in the same amperage range, the air will be larger. One must be careful with different aluminum filler rod if the part getting anodized, I screwed up.
.....=o&o>.....
Beemer, did not consider amperage differences in torches. My old weldcraft 150 aircooled is bigger than my current weldcraft 250 watercooled. Although other brands may vary.
You would also be correct about the anodizing thing. One more tip from a self-proclaimed aluminum expert that directly relates. Better-Built truck tool boxes (Daws MFG.) produces their super shiny (clean) welds by using the same material as filler rod. So for any of you doing any home projects out of sheet aluminum that you will polish or anodize afterwords, do yourself a favor. Buy a larger piece of sheet than you need, take it to a sheetmetal shop and have them shear you off 1/8" wide strips to use as your filler metal for welding said project together. Daws actually bought a de-coiler and precision shear just to make thier own filler rods, it is just one of the ways they reduced their bottom line to increase profits. 5' long filler rods vs. 3' that they pay for buy the lb, not the whole roll. Big time savings realized. To think I learned all of this from a job interview that I did not take. Knowledge is power.
Hi, i have a miller 110 volt unit i use it in my mower shop . If i could do it over again i would get the larger size up ! & yes i use gas on my unit it's the only way to go.
Ryan
Several years ago we were repairing a transmission cover on an old Harley XLCH. One corner of the case was completely gone so we made a mold of the corner from a good case, had a new "corner" cast, and TIG welded it on. We sent a sample of the case we were repairing to a metallurgist. The foundry used his analysis to determine the correct alloy and cast the new "corner" in the same alloy as the original case. We had some filler rod of the same alloy prepared and after polishing you cannot see the repair. Seems like of lot of work but the results were worth it.
.....=o&o>.....
TIP: For mig welding body panels, hammer welding or welds that will be ground use ESAB "easy grind" wire. It does not have an alloy # designation nor does anyone else make an equivilent so insist your ESAB supplier orders the right product (most do not stock it for some reason). It should say EASY GRIND on the side of the spool.
