Offroad & 4x4
radius arm drop
Old Oct 15, 2005 | 12:30 PM
god.boots's Avatar
god.boots
radius arm drop
well, As some of you know I have a 4" lift on my 2wd f100 67. I put 4" lift coils up front, and made drop brackets for my i-beams to correct camber. Now I have to drop my radius arms. I was thinking of putting some square tubing between the bracket and the frame, I need to drop it 4" , so maybe some 3x4 square tubing. I would also have to add some other steel because brackets as they sit stock bolt onto the frame, and the crossmember. there is also this link, http://www.jackit.com/radius_arms/ra...p_brackets.htm says says 66-79 f150, does anyone know if these will work with a f100? I doubt they will work for my truck though. What do you guys think?
Old Oct 15, 2005 | 06:45 PM
fishmanndotcom's Avatar
fishmanndotcom
instead of dropping, why not lengthen the arms? it does the same thing!
-cutts-
