Need Help with Door Sticker Axle Codes
Old Oct 15, 2005 | 06:34 AM
rs899's Avatar
rs899
I have a 67 F-100 and am looking to find a lower numeric ratio differential. The upullit where I am a regular has a sale this weekend on diffs for $20.
As it happens , all the truck are picked over and the Econoline vans are left.
None of the diff have their tags!. They may have been removed by someone who was looking (?!).
Anyway- I basically have found vans with these door sticker axle codes:
1979 code 13
1983 code 16
1985 code 13
1979 code 13
1985 code 16
1983 code 13
Anyone know what these 13 and 16 9" axles are for these years. I sure as heck can't find any decoding info on this or any site. I have a Clymer's manual for Ford vans for that year and it doesn't even mention the diff , let alone talk about the codes or ratios.
thanks
Rick
Old Oct 16, 2005 | 01:23 AM
Racerguy's Avatar
Racerguy
I can't help you with the codes but you could try posting in the Clutch,Transmission, Differential, Axle and Transfer Case forum which is a ways further down on the main forum page.
Old Oct 19, 2005 | 01:22 PM
Gene W's Avatar
Gene W
Be sure to measure the length of the rear end you are considering purchasing and compare it to the one you have in your truck.
I can't say for sure if they are different lengths but I do know that in the later models the vans chassis is wider than the F series. They may use the same width axles with perchs welded on in a different location.
Gene
Old Oct 19, 2005 | 01:33 PM
rs899's Avatar
rs899
That's not a consideration- I just need the center section (to fit 28 spline axles). I eventually found my answer on another post. The 13 code for those years was 2.75 and the 16 was 3.75- which is what I have. I think 2.75 is going to be too radical so I'll look around for a 3.25. This place has rear ends on sale every month or so so I'll get one (for $20!) eventually
theoldwizard
Sep 8, 2015 11:32 PM
jyblood
Feb 16, 2014 03:25 PM
Techfree
2004 - 2008 F150
Dec 20, 2010 07:58 PM
thiggy
1997 - 2003 F150
Oct 14, 2010 03:04 PM
glasstruck
Apr 17, 2007 06:14 PM
