1978 - 1996 Big Bronco
Draining battery
Old Oct 14, 2005 | 10:48 PM
Fordbyford's Avatar
Fordbyford
Draining battery
Ok heres the deal my 1996 Ford Bronco XLT 351 auto the battery is being drained for some reason It drained down low enough to mmake it so I had no lights no nothing so I went and had it charged so today I hooked the battery back and started it sounded pretty good so I turned it off and let it sit for an hour or 2 and went back out to start it up again went to start it and lights went on but then faded out and heard a load clicking noise coming from under neith the passanger side of the hood and would start but since then its been about 5-6 hours I'll go outside and check to see if the lights are working or not they are working good but any ideas what the problem(S) could be i might have a open circuit some where but I don't know where to start looking
Old Oct 14, 2005 | 11:27 PM
Tazz452's Avatar
Tazz452
It is possible that the battery is going bad. Do an acid test or take it to a parts store. Most of them can do a load test on your battery to see if it holding a proper charge under load. Also might check to see if your hood light goes off when it is shut. I don't know if there is an easier way but you could also hook a meter to your battery and "watch" the voltage. then start pulling fuses one by one to try and at least narrow it down to a circuit.
Old Oct 15, 2005 | 09:02 AM
scurbiedog's Avatar
scurbiedog
Take it to a garage or even"do I dare say it I know most people dont like them "Auto Zone, they do have the tester to check your battery and alt, also check your cables for corrosion, I had a neg, cable that had split its casing down at the bottom where it bolts to and kept losing its charge , when I replaced it the battery stayed charged.
Old Oct 16, 2005 | 10:28 PM
greystreak92's Avatar
greystreak92
Definitely check or have the battery checked first. If you have an open circuit, you can check it with a meter at the battery but it won't tell you where the problem lies. Not to mention that an open circuit that can drain a fully charged battery in a few hours has to be something larger than just a clock or computer circuit. It would almost have to be a short which will eventually lead to a wiring meltdown or a lighting circuit which you will be able to see once it gets dark.
phurst
Jul 6, 2011 03:51 PM
borealak
Electrical Systems/Wiring
Feb 27, 2011 05:08 PM
tweaked250r
Mar 25, 2008 05:01 AM
darkwingduck
Oct 26, 2005 11:22 AM
