Offroad & 4x4
Front leaves
Old Oct 14, 2005 | 12:29 PM
crack's Avatar
crack
Front leaves
im looking for some springs for a 4inch lift but everywhere seems so expensive, one place I called was trying to charge 370 a corner! where could I get a cheap set?
Old Oct 14, 2005 | 01:13 PM
r0n1n's Avatar
r0n1n
www.suspensionconnection.com
www.ntwonline.com
www.rockymountainsusp.com
-jason
Old Oct 14, 2005 | 02:04 PM
fishmanndotcom's Avatar
fishmanndotcom
370 a corner sounds a lil high but not by much! keep an eye on ebay, there are always spring packs for sale there
a whole lift kit from National tire and wheel is right at $600 then after shipping and taxes and all the accessories it's above 700 but if you just want the springs call up skyjacker and tell them what you want and who you've been too and see if they will do anything for you
-cutts-
Old Oct 14, 2005 | 02:20 PM
crack's Avatar
crack
ok another question...will front springs fit from the 80-97 on a 79?
Old Oct 14, 2005 | 09:53 PM
fishmanndotcom
you can always make them fit but no i dont think they are interchangeable. if i remember right they are 2.5" wide aren't they?
-cutts-
Old Oct 14, 2005 | 11:07 PM
mustange70's Avatar
mustange70
The 79's should be 3", as ivan was able to use a set off a superduty i believe and those are a 3" wide leaf.
Old Oct 15, 2005 | 07:52 AM
fishmanndotcom
o ok, well where were the 2.5" leaves used?
-cutts-
Old Oct 15, 2005 | 09:50 AM
bremen242's Avatar
bremen242
I think that might be a highboy thing, but i'm not 100% sure
Old Oct 15, 2005 | 11:37 AM
crack's Avatar
crack
Ive heard of the highboys being 2.5 and "lowboys" being 3...so I guess they would interchange.?
Old Oct 15, 2005 | 11:51 AM
75crewcab's Avatar
75crewcab
F-250 front springs for highboy are the same as the 771/2-79 fords. Highboys are just taller. the rear springs on highboy are 2.5" and 771/2- 79 are 3" I had a front set made for my highboy by alcan spring in grand jct. colo. they flex good and were around $215 a corner.
Old Oct 15, 2005 | 11:54 AM
crack's Avatar
crack
I think I found a place I can get them 225 a side...and thats canadian
Old Oct 15, 2005 | 01:09 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
80-97 springs are 3 inch but shorter than the 73-79 fronts, and shorter than the 99-04 superduty springs. i woudl also calla round and ask about "scratch and dent" springs. they are usually a good bit cheaper and jus thave minor cosmetic defects
Old Oct 15, 2005 | 10:02 PM
bremen242's Avatar
bremen242
I knew something was 2.5" on the hi-boyz
Old Oct 15, 2005 | 11:54 PM
mustange70's Avatar
mustange70
THanks for clearing that up KO.
Old Oct 16, 2005 | 05:55 PM
KubotaOrange76
arent the hiboys 2 1/4??
