When I shift from reverse to nuetral on a 1977 F-150 the starter kicks in for a mili-second.Truck won't crank but in Park or N. Any ideas? And Thank You Veterans.
[updated:LAST EDITED ON 27-May-02 AT 01:05 PM (EST)]You probably have a short that goes to the wire that's attached to the S terminal of the starter solenoid.
I'd check the neutral safety/start switch.
