fuel filter
Old Oct 13, 2005 | 07:10 PM
fordguyforlife's Avatar
fordguyforlife
fuel filter
im about to change my fuel filter in my '03 F150 for the first time. do i need to releive any pressure in the fuel system and if so how do i do it?
Old Oct 13, 2005 | 09:28 PM
BrianA's Avatar
BrianA
YES
Find the inertia sensor fuel cutoff (which I believe is located behind the kick panel on the passenger side in all F150s). Unplug the connector that goes to the relay.
Crank the truck and let in run until it dies. The fuel system is now depressurized.
You can safely remove the fuel filter.
Do you have the special tool to remove the filter?
If not, stop by local parts place and get one. You will need it.
After replacing the filter, plug the relay back up and you are ready to go.
Remember to check for leaks.
Old Oct 13, 2005 | 10:05 PM
fordguyforlife
thanks for the quick reply BrianA. yea i already bought the tool today. plannin on doin a fuel filter change, oil change and trans fluid change. 34,000 miles, and not a single problem. hopefully all goes smooth.
Old Oct 14, 2005 | 11:23 AM
fordguyforlife
could i just pull the fuse for the fuel pump and then start it up and let it die?
Old Oct 14, 2005 | 05:13 PM
BrianA's Avatar
BrianA
I'd suspect yes, I just never tried it that way.
I can't see how it wouldn't work.
Old Oct 14, 2005 | 06:11 PM
fordguyforlife
i didnt even think of it untill my friend mentioned it. thanks for the help.
Old Oct 15, 2005 | 04:57 PM
fordguyforlife
everything worked out fine except for the tool for the fuel filter. lets just say it was defective. lol. thanks for the help Brian.
