vapor lock
Old Jun 1, 2002 | 04:08 AM
fyrfytr's Avatar
fyrfytr
vapor lock
What is best to use for gas line to help avoid vapor locking, steel or rubber?
Thanks,
Terry
Old Jun 1, 2002 | 06:19 AM
wayne_j's Avatar
wayne_j
vapor lock
I personally never recommend the use of rubber lines when it comes to fuel. I know you'll find some on here that will disagree, but with the cost of steel lines only being a few cents more per-foot then rubber, you can't ignore the safty factor. The best way to avoid vapor lock is to keep a cool running engine (between 160 and 180*f). Then make sure you run your lines as far away from any heat sourse as possible. Keep the lines away from the exhaust and heater hoses and off the intake manifold as much as possible.
Old Jun 1, 2002 | 07:20 AM
rdlehman's Avatar
rdlehman
vapor lock
