pi D
Pi is 3.14 roughly times the Diameter, like my truck would be since i have 31 inch tires (well you should measure not go by the letters)
3.14 X 31 = 97.34 inches around.
Now if you wanted to find the area of a tire you would go 3pi times r squared x width.
which is 3.14 X radius squared X width so for me it owuld be 3.14 x's (31/2) squared in other words (3.14)X(15.5 X 15.5)X(10.5) which comes out to (3.14)X(240.25)X(10.5) which is 7921.0425 or 7,921.04 inches. I dont know why i posted the tire area, but thats how much air you need to inflate it, lol. plus you need so many PSI, so you can figure the rest out. lol
Haha, thats awesome. I bet you wouldn't see such a smart group of guys on a cheby website. Jk. Who knew my years of algebra, geometry, trig, anc calculus would come in so handy.
wait i forgot, you have to subtract the wheel size. so for me lets jsut say out of curiosity, not minus all the little nick nacks and stuff you take my wheel 15 X 8.5 so you multiply (3.14)(7.5)(7.5)(8.5) ok that gives us 2495.71125 so you take the orginal tire size calc and subtract 2495.71125 from it and it gives us (7921.0425)-(2495.71125) which equals 5425.33125 so therefore 5,425.33 cubic inches of air space. sorry i forgot that part earlier
I should know this from the chemistry and physics class I took, but if my tires were filled with nitrogen, would that have any effect on air space. I dunno how that expands.
The new ones are 110 inches in circumference. The old tires that were on there were not stock though. They were 31X10.5X15, so I should use the stock circumference for the 29 inch tire. If my calculations are correct, a 29 inch tire would be 91.1 inches around. Does that sound right? So the difference is 18.9 inches. What do i do with that number now?
The difference is not what you use. You want the percentage value. (91.1 divided by 110 is .828 so you have a 17.2 percent increas in diameter.) Take your old speedo drive gear to the Ford parts counter and try to get one 17 percent smaller. Your speedo is reading slow with the larger tires so you have to speed up the speedo by using a smaller driven gear.
Bdox, I think I gave him the wrong info. It's been a long day.
jpjahn, Sorry about that.
I guess my speedo situation was a different because of the rear end ratio change.
So I guess you need a either a 16 or 17 tooth driven gear. (20 x 17%=16.6)
jpjahn, again sorry about that.
EDIT:Bdox, Are you absolutely sure?
The more I think about it, the more I want say a bigger gear.
Here's how I see it.
With the bigger tires, say you're actual speed is 60MPH. Isn't the speedometer reading a much higher number? The rear wheels are spinning the speedo faster.
So wouldn't the drive gear have to be bigger to slow down the speedo?
Now I'm confused.
Aw shoot, I think your're right.
When you install larger tires, your speedo reads too slow. So you now need to speed up the speedometer to match your speed. Since the speedo drive gear is the "driven" gear it needs to have fewer teeth to drive the speedo faster.
