Sponsored by: Auxito
Horn stopped working
Old Oct 13, 2005 | 10:27 AM
FourthFordTruck's Avatar
FourthFordTruck
My horn on '97 F-150 Scab 4.6 stopped working.
It sounded funny the day before it quit. The fuse and
relay both check out as okay. I put on a new horn but
still doesn't work. I can hear the relay click when I hit
the horn button. Thanks.
Old Oct 13, 2005 | 12:05 PM
lancekilgore's Avatar
lancekilgore
My 2000 had two hornes a low and a high the low went out and I had to replace them both to get it to work properly. Strange! tried replacing jus the low but to no availe. hope this helps or if you have two horns or just a single horn.
Lance
Old Oct 13, 2005 | 12:14 PM
FourthFordTruck
Gotcha. Mine has the dual horns.
Thanks for the help. I'll post back with results.
Does it matter which of the two wires you hook on which horn or onto which posts?
Old Oct 13, 2005 | 12:28 PM
lancekilgore
Mine were set up to only work one way, I put them back the same way, alaso check the wiring one of the wires had to be changed because of corrosion.
Old Oct 13, 2005 | 02:11 PM
framerboy's Avatar
framerboy
I am not sure about the 97's but at least on my 2002 when the horn stopped working, it was a faulty "clock spring". Your friendly ford service department has all the details.
