Sponsored by: Real Truck
Outside temp reading
Old Oct 13, 2005 | 07:15 AM
locked up's Avatar
locked up
My temp reading on my overhead use to be very accurate. This morning on the way to work my daughter said dad I don't think its 133 degrees out. Any idea what may be wrong. New sensor? Any help greatly appreciated.
Old Oct 13, 2005 | 07:21 AM
350z's Avatar
350z
Sounds like it was switched from f .to c.
Old Oct 13, 2005 | 07:45 AM
locked up's Avatar
locked up
No it was reading about 54C, which I believe would be right. The opposite of F.. Thing has be flawless...Any other ideas greatly appreciated.
Old Oct 13, 2005 | 07:53 AM
Kraut's Avatar
Kraut
if the number being reported is the only thing wrong... then sensor...
Old Oct 13, 2005 | 08:06 PM
wolfbike1500's Avatar
wolfbike1500
I bet is is a sensor, or the wiring to the sensor. I work with sensors and a lot of them have a failure mode that depends on the failure. A full scale temp reading can be caused by a short in the wires going to the sensor or by a failed sensor. An open circuit in the wiring would have the opposite effect and there would be no reading, or some meaningless value displayed. I think the sensor is in the air intake near the MAF sensor.
Old Oct 14, 2005 | 06:25 AM
locked up's Avatar
locked up
Thanks...I took the sensor out and it did do the opposite went to neg 40 Ordered a new one...When I put it in, should I coat the end with anything?
Thanks again
