Fuel Consumption (Range)
Old Oct 13, 2005 | 06:05 AM
oldcoupe42's Avatar
oldcoupe42
I have a 95 F150 Extended with a 4,9 I6 motor, what type of range do owners of similar vehicles get on a tank of gas ? (I have 2 tanks on mine)
Thanks, Chet
Old Oct 13, 2005 | 08:22 AM
KW160's Avatar
KW160
I have a 1996 F-150, 5-speed, I-6, regular cab, 2.73 rear, long bed, 2WD, single tank and I try to go 300 mi between fill-ups. (avg 20mpg)
Old Oct 13, 2005 | 09:52 AM
oldcoupe42's Avatar
oldcoupe42
Forgot to mention I have a C-6 Auto trans (Yes I know F150s did not come with C-6 it was a custom swap for my old Mazda 5 spd)
Thanks, Chet
Old Oct 13, 2005 | 11:44 AM
pfogle's Avatar
pfogle
I'd realistically expect 14~16 with a C6 depending on the rear gear ratio.
Old Oct 13, 2005 | 12:06 PM
oldcoupe42's Avatar
oldcoupe42
Thanks guys, Im' guessing my duel tanks are 19 and 21 gallons respectivly ?
Chet
Old Oct 13, 2005 | 01:37 PM
alz's Avatar
alz
My 95 Supercab w/302 has 16 gallon and 18 gallon respectively. I get 275 miles per front tank.
Old Oct 13, 2005 | 03:51 PM
andym's Avatar
andym
If you have a longbed, the front tank is 18.5. Shortbed and the front is 16.5. The rear is 18.2 regardless.
I get 15 in my 1991 below. You may get less than I do with a C6. No overdrive.
Old Oct 13, 2005 | 03:54 PM
Popa Tim's Avatar
Popa Tim
I get 15 in my 94 F150 4x4 5.o. You should be comparable if you're 4x2 and less if you're 4x4 too. What gearing do you have?
Old Oct 13, 2005 | 05:44 PM
onebluemcm's Avatar
onebluemcm
Popa Tim - Sounds like you're saying the 4.9L chugs the fuel a bit more than the 5.0L, everything else equal - didn't know that. Figured they be about equal....
