Seat for an F-1
Seat for an F-1
I'm looking for a seat to replace the original bench in my '48 F-1. The seat is in excellent condition, with reasonably fresh padding and upholstery, but like a lot of old Ford vehicles, the seat springs are part of the "suspension," as in it bounces. I'm softening the original suspension spring packs on the truck, plus the tires are radials, so I don't need help from the seat springs for a comfortable ride.
I'm thinking a seat from a modern mini or mid-size truck might fill the bill, with better contouring and support, and without seat-spring bounce. It wants to be about 52-53 inches wide for the base as well as the back.
Any suggestions . . . good places to start?
TIA for any and all suggestions.
Mike Bishop
Santa Rosa
Mike Bishop
Santa Rosa
You also need to think about the seat back - the distance between the steering wheel and the front of the back seat. You need to be able to sit easy and not have the steering wheel rubbing on your belly - our cabs are not as deep as the more modern ones.
Some of us have grown a few inches in the front since we were lads!
One of the features I'm hoping to find in a late-model bench seat is a thinner seat back than the 6-inch couch cushion in my F-1. I'd like to be able to recline it back a few degrees and move me back a couple of inches from the steering wheel.
The Ranger bench sounds like it may be what I'm looking for.
Mike
on
Mike
Mike
That's exactly what I did with the 90 Ranger regular cab bench seat I am using in my 48. With a little work you can utilize the stock 48 seat tracks and bolt it in the same place as the original seat. I sawed about three inches off the rear legs of the original brackets and added some angle iron to recline it and it still clears my gas tank with no problem.
Vern
When you installed new seats what height did you set the front top surface of the seat at? I am looking at floor to top of upolstory. My original seat (slightly beat down measured 14 1/2 inches. Right now I have a set of 90 Ranger split bench seats (from my old truck) tacked in place at 16 inches since with the 3 1/2 inch tilt back I(same tiltback as my 03 split bench tiltback), it otherwise seemed to sit too low. I am 5' 10" and wanted my line of sight to be in the middle of the windshield height on my 49. Anybody?
on
I don't think my measurements are going to help you. I'm 6'2" and also wanted to see through the center of the windshield so mine is lower than the original seat since the Ranger seat bottom is thinner. Looking out the windshield with the original seat I was looking through the upper 1/3 of the windshield. When I attached the original seat bracket it was perfect for me so I didn't have to change the height at the front. I also used a bench and the buckets might be a different height...
Vern
Vern
Originally Posted by f1fordguy
I would love to see some pics as to how you fellas adapted the original seat frame to a Ranger seat. This is my next battle. I have a Sonoma seat because I wanted 60/40 with an armrest.
Anyone use a seat with integrated shoulder rests? Seems like this would solve two issues at once.
Unfortunately I am still without a digital camera or I would post a pix.
