Greetings from KingRanchMan02
I am the proud owner of a 2002 F150 4x2 SuperCab Lariat King Ranch, 5.4L, 3.55 Limitied Slip, 6300# GVWR, and Class III towing package. I purchased the truck new Sept. 7, 2002. The color is Charcoal Blue/Arizona Biege. Just under 45K miles.
Since that time, I added a body color Line-X sprayed in bed liner, a body color painted Lund bug deflector, and Bull Ring pop up tie down rings.
The only engine related mod is a K & N filter, and full synthetic Pennzoil Platinum oil.
The only trouble that I have had is with the EATC in that occasionally the blower squeaks. This is intermittent and is a little annoying.
Does anyone know a cause/fix for this?
Oh, one other thing, the automatic dimming rear view mirror vibrates enough to give a blurry image.
Other than these minor things, I love my truck
.That's enough for now.
KingRanchMan02
If you get a minute check out the link here, it will help you to navigate around and understand this site. https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards.
A little history on my 05 Excursion with 6.0 Powerstroke. A/C control head just went blank one day so I pulled the battery cables and put them back and it worked again. happened a few more times with same results. Then went into winter and used only heat. As spring came around, tried to run A/C and regardless of temp setting on control head, only heat came out. Then EGR cooler went out and it took me a month to get to it and do the delete. Now, only get room temp air (outside aire) when on A/C. control head isn't blank but no cold.
Any light you chould shed would be most appreciated.
Thanks.
