Steering wheel replacement options
Old May 31, 2002 | 05:56 PM
Chu's Avatar
Chu
I want to put a nice padded steering wheel(something better than the thin thing that they came with) in my 77 f-350, and was wondering what others have installed on their trucks
Old May 31, 2002 | 07:38 PM
leadmic's Avatar
leadmic
Check out the Grant wheels at summit. They even have a set up to run the factory cruse on the wheel.
Leadmic
Old May 31, 2002 | 07:46 PM
Chu's Avatar
Chu
I was looking at them this AM, but I was trying to find a boneyard replacement. Something that I could swap in for short $$$
Old May 31, 2002 | 09:16 PM
79f3504x4's Avatar
79f3504x4
Some vans up to 91 have a wheel similar to 78-79 truck wheel but with a fatter grip.Cheap at the junkyard.Brian
Old May 31, 2002 | 11:37 PM
trinogt's Avatar
trinogt
I found a new three spoke chrome wheel with fat rubber rim at the wreckers. I got it and the adapter splines for 10 bucks. I priced the same wheel at the store for 50 bucks and another 35 for the adapter.
CAD prices. If you want a pic, I can send you one. It looks great in there! The original horn didn't work and I couldn't find a problem in the wiring, so I ran new wire to the horn and a push button mounted under the column... I had a wheel like this before, and the horn never worked properly anyway... ended up shorting and the horn was in the on position!
Mark
Ford started it; Ford will finish it!
Old Jun 1, 2002 | 01:31 AM
luv70sfords's Avatar
luv70sfords
Post Steering wheel replacement options
Im runnin the el cheapo Grant wheel in my truck. Actually like it over the stock do to the smaller diameter. Much easier for whippin around offroad.
Old Jun 1, 2002 | 11:11 AM
wrangler76's Avatar
wrangler76
I run a Ford Stock "GT" style 3 spoke style rim. I've seen them in F-Series Ranger trim 70's pickups and 70's/early 80's Mustangs. Ebay always has some for sale.
Old Jun 1, 2002 | 12:39 PM
Chu's Avatar
Chu
Does anyone have any pics on file to share with the group???
Old Jun 2, 2002 | 12:00 AM
trinogt's Avatar
trinogt
I could get you a pic of my junkyard special Grant three spoke chrome wheel as early as tomorrow.
Mark
Old Jun 2, 2002 | 12:25 AM
Chu's Avatar
Chu
Cool thanks
Old Jun 3, 2002 | 05:53 PM
trinogt's Avatar
trinogt
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=5294&.jpg
Here is the Grant wheel I got fron the wreckers. It is the smaller Grant wheel. I found a larger one at the store if you are into that. I find this the right size for me.
Mark
Old Jun 3, 2002 | 06:28 PM
Chu's Avatar
Chu
I like that. Something a little thicker in the hands. The thin wheel Ford gave us just doesnt fit the brute strength and power that the truck calls out for
Chu
Old Jun 3, 2002 | 09:49 PM
trinogt's Avatar
trinogt
You might have to get used to the smaller radius of this wheel... It takes smaller inputs to correct your steering with ruts or crosswinds.
Otherwise, it is a pretty nice feel! The horns never work for me on these wheels, so I rig up a horn button below the column where you don't see it. (the steel column mount found on pre-'78 trucks... they switched to a larger, plastic column shroud in the later years, where you could actually pull the wiring connector through.)
Mark
Old Jun 3, 2002 | 10:36 PM
Mil1ion's Avatar
Mil1ion
