IAC VALVE 98 4ltr EXPLORER
Old Oct 11, 2005 | 03:05 PM
doug42's Avatar
doug42
HI. IM having trouble with engine staying running.iac valve tested ok electrically,i removed valve and bench tested. i can feel the solonoid operating but the valve stem is not moving. i can move it manually whether solonoid energized or not. is stem supposed to be attached to the plunger of the solonoid. thanks.
Old Oct 11, 2005 | 06:37 PM
vicv's Avatar
vicv
Yes it should be attched. The stem should move the plunger in and out thus opening and closing the valve.
