changing motors
Old Oct 11, 2005 | 12:16 AM
gramps43701's Avatar
gramps43701
changing motors
Hello all, I'm changing motors in my 80' f-150 from a 5.8m (351m) to a 302. I need to know what I need to change on the tranny. It is a c6 not sure if the bellhousing is the same or not.
Old Oct 11, 2005 | 12:27 AM
Franklin2's Avatar
Franklin2
The bellhousing is not the same. A 400 or 460 would work. A 400 would drop right in, and the exhaust and everything would fit. If you got one from a car, you could even use the rear sump oil pan from the 351m.
Old Oct 11, 2005 | 08:38 AM
Sycostang67's Avatar
Sycostang67
No dice there, to put in a 302 you have to swap the tranny. The FMX and C4 trannies have removable bell housings, but the C6 is one piece.
