Supercharged???
Old Oct 10, 2005 | 09:54 PM
Cntry125's Avatar
Cntry125
Supercharged???
I am wondering if anyone makes a supercharger for the 300??? and if they do im wondering the cost and where to find such a beast????
Old Oct 10, 2005 | 09:59 PM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following: Forum Guidelines
Please view the main forum page to find the best forum to ask any Technical questions.
Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
Old Oct 11, 2005 | 07:00 AM
Motorhead351's Avatar
Motorhead351
No one makes a kit.
The good news, with a little creativity you can make one work easy enough, the main hurdle is a bracket to hold the supercharger, all doable. Obviously, the easiest kit to adapt, would be one intended for a 5.0 Speed density truck, if you have an efi truck. If you have a carbed truck, the same supercharger would work but the rest of the kit would be useless, then you'd wanna learn all you can about blow through carb setups and whether you wanna go with a bonnet or enclose the carb in a box, depending on boost levels, etc.
Depending on your anticipated boost levels, you'd definitely wanna look into a stronger head gasket.
Old Oct 11, 2005 | 02:41 PM
sierraben's Avatar
sierraben
Check out this site. I just found it a few days ago.
http://www.esuperchargers.com/
Old Oct 11, 2005 | 02:52 PM
Motorhead351
http://www.esuperchargers.com/ .
Umm....good luck with that...
Old Oct 11, 2005 | 02:58 PM
fordborn's Avatar
fordborn
I don't think you would get what you'd hope useing those. LOL
Old Oct 11, 2005 | 03:02 PM
sierraben's Avatar
sierraben
It does seem like a fly by night way to super-charge an engine.
That was my first thought when I saw that site.
But I'll let someone else to an investigation on that product.
I personally don't need or want a supercharger.
More maintenance and more wear and tear on the engine.
If someone is serious, think PAXTON.
JMHO
Well, I decided to do a quick research on that "esupercharger".
Don't even bother.
Old Oct 11, 2005 | 05:24 PM
Silver Streak's Avatar
Silver Streak
Originally Posted by sierraben
=BS! Did anyone notice the dyno chart they had on the site? The two curves are nearly identical.
Old Oct 11, 2005 | 08:14 PM
rhetor's Avatar
rhetor
I don't know if mounting the blower would be the hardest part.
tuning would not be fun. The computer expects to see a 300 with a certain range of variables. when you strap a blower on there, the computer is going to virtual-**** its e-pants.
Old Oct 11, 2005 | 08:16 PM
sierraben's Avatar
sierraben
Can't expect much with a 2 lb. boost.
The alternator is going to put more of a strain on the engine than what you can get from this e-supercharger.
Old Oct 11, 2005 | 09:03 PM
shmoozo's Avatar
shmoozo
I don't know of any kits, but I do have seen pictures of Ford 300's which had superchargers. One had a Kenne Bell supercharger mounted on top of an adapter attached to what I think was either an Offy or Clifford 4-barrel intake. The intake port on the back of the supercharger had a tube which came out and bent back around to the outboard side of the supercharger and there it had a 4-barrel carb mounted so rather than the carb being set up in a "blow through" configuration, it was set up in a "draw through" arrangement.
I've also seen pictures of at least one turbocharged 300. The one I saw was an EFI model, but I think you could also turbocharge a carb version of the engine. I'd probably suggest a blow through carb setup for that. The main difficulty with a turbo setup is all the intale and exhaust "plumbing" turbos require.
Somebody else here already suggested a Paxton supercharger. That would also work on a blow through carb setup, as well as an EFI engine. The main difficulties with the Paxton would be creating a mounting structure to attach it to the engine so it could be belt driven, and rigging up "plumbing" to channel the air into the engine.
There's a variety of differences in the performance characteristics of different kinds of supercharging systems. Positive displacement blowers (Roots blowers as well as screw type blowers and such) have certain advantages in terms of producing boost at just about any RPM which means that even in the stump pulling low-RPM ranges often used for towing and hauling in the real world you can have decent boost. Turbos and centrifugal blowers (of which Paxton is perhaps the most well-known example) tend to produce less boost at lower RPMs, though a turbo that is properly sized and setup with the correct accessories can be quite good at providing good boost across a fairly broad range of RPMs.
There are some very good web sites which explain the fundamentals of supercharging. Some of the best sites are actually the ones for the vendors and manufacturers of the superchargers.
Try these web sites for good info and some product choices:
http://www.paxtonauto.com/index.html
http://www.paxtonauto.com/faq.html
http://www.kennebell.net/index.htm
http://www.superiorairflow.com/
http://www.magnusonproducts.com/
Old Oct 11, 2005 | 09:14 PM
Motorhead351
no differnt than a 302 SD computer it expects to see certian variables, thats why they offer the addional fuel delivery components, etc., thats why they offer a bag of tricks with the supercharger..
Old Oct 11, 2005 | 09:17 PM
sierraben's Avatar
sierraben
As for tuning, I would think pre-computer engines would be no problem.
Old Oct 12, 2005 | 07:59 AM
Silver Streak
Tuning is a non-issue. You can run an FMU in the fuel system that raises pressure proporionately to boost and it will be fine. The computer will never know the difference other than the MAP sensor reading is occassionally a little wierd, which can also be overcome without much effort. Bigger injectors would be a good idea to keep the fuel pressue within reason.
Old Oct 12, 2005 | 08:10 AM
77300i6's Avatar
77300i6
As long as you know how to tune a carb and the ignition properly. Otherwise, your pistons might become a molten pile of metal in the oil pan
Check out http://www.fordsix.com and http://turbomustangs.com
Wealth of info there for your forced induction needs. I would go with a properly sized turbo for a 300L6. As stated before, they can produce power at relatively low RPMs. Although, you may be able to overdrive a S/C to work at lower RPMs, but I'm not sure if that would reduce the life of it.
Wouldn't be nice to have a TT intercooled MPI 300L6?
